GE's channel list shows encrypted channels as FTA
Derrick
..just made a fresh scan from hotbird. After deleting hotbird in my settings and importing the new ini, all encrypted channels are shown as fta. The Pro version shows them as they should appear.
GE 1.7.3
ps. all encrypted symbols in the channel list have disappeared.
Nobody?
All encrypted channels -> Encrypted=1 that are imported change to Encrypted=0 after the GE is closed and reopened. All channels in the export.ini have Encrypted=0
same as above (scanned with TransEdit 2.3.5) but after im/export:
If scanned with the internal scanner of the DVBViewer, Encrypted=1 is kept.
The same exported list scanned with the internal scanner:
DVBViewer GE doesn't support decryption, so it's useless to import encrypted channels anyway.
However, I will look after these things when I add CI support (at least for SkyStar1/Twinhan) in version 1.9.
