oleg_s Posted January 9, 2006 Posted January 9, 2006 (edited) hi there! i got a problem with russian provider NTV+ on 36E: channel names (after scan) and EPG info are displayed in wrong encoding. (btw, i can edit ch. names manually and they are proper displayed) is there any solution for cyrillic names? ps. i'm using full version for € 15 added: this problem was in old version of progdvb (http://www.progdvb.com): ProgDVB 4.51 Use unicode for channel names, epg, subtitles,... All national symbols should be displayed correctly. so, does DVBViewer use unicode in ch names and epg ? Edited January 14, 2006 by oleg_s Quote
oleg_s Posted January 17, 2006 Author Posted January 17, 2006 talk to myself, part 2 found EPG v.039.6 by Relict Marauder (md plugin), put epg.dll in Mdplugins folder and ...its works cyrillic characters are ok in epg. so , again, are there possible the right cyrillic characters in ch names and epg in вмимшуцук, regards Quote
