Displaying UK Freeview Subtitles?
studavis
Hi there
I have a WinNova-T DVB-T card that I use with DVBViewer to watch UK freeview television. Is there any way that I can turn on the subtitles in DVBViewer?? I just see no option to do it. Is it a limitation of the card or the DVBV software??
thanks in advance!
Hmm what do you mean? MHEG or Teletext resp. DVB Subtitles. The last two are definitively supported by BBC and can be also watched inside the DVBViewer. MHEG is not supported at the moment, as well as MHP. I have it on my todo list, but the priority is quite less - since the most european countries (especially germany) do not excessively use it.
Christian
i know MHEG isn't supported - it's the subtitles (of the type that used be on 888 Fasttext on normal TV). How do you turn them on in DVBViewer?
Select View Subtitles, and then select the English stream under DVB Subtitles (by default the subtitle stream will not be selected). It worked for me in 3.2.5 but I haven't tried it in 3.2.6 yet.
