Sonique plugins
lunkan
How to get G-force to work with latest version of DVBViever Pro ?
Other sonique vis. plugins works ok. I've tryed both G-force ver. 3.1.2 (latest) and 2.7.1
Krister
Some Visual Plugins require a path inside the sonique installation, e.g. c:\program files\sonique\plugins. I'm aware of this, but after you created it, even the gforce should run.
Christian
I have no problem with install G-force (ver. 2.7.1) and I've also have sonique installed.
Think there must be som sort of bug in DVBViever. OSD menu hangs. If I cange visualation ( In Settings) when playing music I can get G-force to start but only the start screen of G-force. (no visualation).
Well i wonder why everybody points to the application which uses the plugin if something went wrong. I testet an older version of gforce here and the problem is simple:
the function RenderProc which is responsible for painting the image raises a division by zero. It seems that there is a bug inside the visual function which is not shown in sonique.
Christian
PS: I made a work around, according to http://groups.google.de/group/borland.publ...826c513c4454749.
It should work with gforce in the next release.
Thanks for the kindness to do a workaround for the problem that I understand is a bug in G-force. Love DVBViewer :) This is the best app for DVB and also it has nice "HTPC features". :(
Playing MP3 a lot and it vill be great to have G-force working :)
Krister
