sasha Posted January 22, 2006 Posted January 22, 2006 Is there a way to make recording icon always visible (while the recording is on) I think it is the picture: record_button.png. I would do it my self but yust dont understand definitions of XML files used for setup. Quote
sasha Posted January 22, 2006 Author Posted January 22, 2006 Never mind. Just edit setup.xml file (DVBViewer main directory), find this line: <entry name="DispRecBtn">0</entry> and change it like this: <entry name="DispRecBtn">1</entry> Quote
Guest Lars_MQ Posted January 22, 2006 Posted January 22, 2006 You could simply have used the options dialog... Quote
sasha Posted January 22, 2006 Author Posted January 22, 2006 (edited) well only if I've known that. Now siriusly I couldn't find that setting in DVBViewer. But "Alls Well that Ends Well" Edited January 22, 2006 by sasha Quote
