Divx frozen frames
damjang
Hi
I converty the recorder stream (muxed mpeg2) to divx5 through dvd2avi, avisynth and virtualdub, but finaly I have a divx file that have frozen frames...
How/or what I can to have a good video?
damjang
Hello!
If you are using DivX 5.0x you'll have to switch off "smooth playback" in your DivX quality settings.
CU, Oliver
I controll, but I have this option disabled before.
I must try to use the unfreze ultility, but I want to do the work right from beginning... maybe this frozen frames are because of bad mpg frames in original recorded stream? Can this be the reason?
damjang
Hello!
Maybe. Try recording in PVA-format and convert the file with PVAStrumento to MPG2-PS. All bad parts are being cut by the program.
You could also try to disable double buffering in your DivX-settings. Sometimes there are problems with WinXP.
BTW: In VirtualDub Mod Avisynth is integrated, you no longer need to create an avs-file on your own.
CU, Oliver
I discover the cause of freezing frame....
I go to quality slider of divx5 options and set to low and all work ok :rolleyes:
Hello damjang!
Well, you should have mentioned it in the first place... :rolleyes:
CU, Oliver
