Mute problem?
sasha
I dont know if this is a bug or not, so I will post the question here.
If I set Mute option in DVBViewer and then close it with power button on my remote control (it reacts like I've pressed Alt+F4 button), next time I start DVBViewer the volume level is down to zero.
So I need to 'volume up' instead of just pressing mute button again.
Is this the way DVBViewer should react or just a little glitch?
Well, for now it's the intended behavior. But after some discussion in the German forum a change has been promised for v4.0
