Channel change problems with Twinhan DTV Sat-CI
mitsu
With the latest DVBViewer Pro channel change behaves a little strange with Twinhan DTV Sat-CI.
Cases:
- Sometimes channel change is very fast
- Sometimes channel change last around 5 seconds
- Sometimes change can take 15 seconds but is successful at last
- Sometimes channel show black screen forever but succeeds after rebuilding graph
- In certain cases after quick channel changes back and forth even rebuild graph shows only black screen. But changing to another channel works normally.
- Worst case happens only with Conax-crypted HD channel (C-More HD). Sometimes black screen cannot be corrected without restarting DVBViewer. Reboot is not needed. In this case processor load stays constantly on around 55% until restart (Pentium 4 3.0G hyperthreading). Normal DVBViewer load is 10%.
Basic cases are the same with free channels and Conax crypted channels. Enabling and disabling fast channel change changes behaviour a little but the cases are still the same.
Bad thing here is that timer recordings are not reliable anymore.
