Aldi MD8800 + DVBviewr Pro V3.2.6.80
Bermar
Scan Astra 19° freezes.
See attached DVBViewer 28-01-2006.log
Configuration:
Medion 8800
713x BDA DVBS Tuner(2) device by DirectX
Can play a few channels. Sometimes I find a few hundred, sometimes a few tenth's, than the program freezes and I have to abort it.
Have Problem solved with Transedit. Scans marvellous. Export and than import in DVBViewer. Works very good. ;)
Next thing is I have 3 LNB's and a 4x1 Diseqc switch. This configuration works with Powercinema. With Transedit I can not scan the other satellites (pos A/opt A Astra 19°, pos B/opt A Hotbird 13°, pos A /opt B Astra 28.2°). ;)
Any ideas to bring the other satellites to live ?
Have further 2 questions as newbie.
1. Have DVBViewer pro downloaded and uses Aldi MD 8800 + 713x BDA DVBS Tuner(2) device. Is it still necessary to install the Technisat Edition + driver software ? ;)
2. I have a problem with my 2 additional LNB's with Disqec switch (see above).
If I look to Astra 19.2° with ini file 19.2.ini it starts with:
[sATTYPE]
1=0192
2=Astra 1B,1C,1E,1F,1G,1H,2C
3=3
4=9750
5=10600
6=11700
If I look to Hotbird 13° with ini file 0130.ini it starts with:
[sATTYPE]
1=0130
2=Hotbird 1,2,3,4,6
Is this correct or .................. is this a newbie question or is this part of the problem ??? ;)
Any for suggestion for using Diseqc 1.0 4x1 swith ? ;)
DVBViewer.log_28_01_2006.txt
Edited by Bermar
