Execute script via input action?
daffy
is it possible to execute a script via an input action?
The plan would be to
* create VBS script
* create input action
then
* trigger input action
* have script executed
I am not really interested in Plugin menu or OSD integration.
yes it is!
Create a Folder called "Scripts" in your DVBViewer-Folder an create a "Command.vbs" in this folder
the command.vbs may contain following commands
sub main(command)
osd.showinfointvpic "Action Nr: " & cstr(command),3000
if command = 21000 then osd.execnewprocess "c:\windows\system32\wscript.exe", "c:\programme\dvbviewer3\scripts\vbs\EPGUpdate.vbs",false,false
if command = 21001 then osd.execnewprocess "c:\windows\system32\wscript.exe", "c:\programme\dvbviewer3\scripts\vbs\DBRefresh.vbs",false,false
if command = 21002 then osd.execnewprocess "c:\windows\system32\wscript.exe", "c:\programme\dvbviewer3\scripts\vbs\freespace.vbs",false,false
if command = 21003 then osd.execnewprocess "c:\windows\system32\wscript.exe", "c:\programme\dvbviewer3\scripts\vbs\ProjectX.vbs",false,false
if command = 21004 then osd.execnewprocess "c:\windows\system32\wscript.exe", "c:\programme\dvbviewer3\scripts\vbs\TimerManager.vbs",false,false
end sub
as you can see, there are new commands from 21000 to 21004. You can create as many as you want but remember that there are already the "intern-commands".
Open the Action-Editor (Option/Input/Add...) afterwards and create a new action with the embedded command.
You could insert your scripts in the command.vbs directly, too - my version above is just one way to solve this prob :(
