daffy Posted January 29, 2006 Posted January 29, 2006 It seems as if DVBViewer will call certain scripts upon internal events: There are several events defined in the DVBViewer which can call a script with defined parameters. This document will explain which events are used, which scripts are called and what kind of parameters are transferred. Basic requirement: The scripts have to be located in the scripts folder in the DVBViewer folder. I suppose it would make sense to create that scripts folder, include a README.txt and, possibly, even startrec.vbs.sample and friends providing a framework to start from? Quote
