brasil Posted January 29, 2006 Posted January 29, 2006 I normally use DVBViewer pro 3 with my remote control (ati remote wonder): I mapped firsts 9 favourite channels on remote control (SHIFT 0, SHIFT 1, etc..) but there is a way to use anothers my favourite channels? For example how can I directly select 11th channel (not with channel +)? Thanks in advance Quote
Guest Lars_MQ Posted January 29, 2006 Posted January 29, 2006 not with the official release, but with the current public beta you can select more than 10 favourites. Quote
brasil Posted January 30, 2006 Author Posted January 30, 2006 Thanks, I just tried public beta and works: for example to swtich to favuorite channel 13, I enter SHIFT 1 and SHIFT 2 in sequence (first favourite channel it's channel 0). To use with my remote control it's possible to set delay between two consecutive commands (in ms)? For example if I press SHIFT 1 and after 1 second SHIFT 2 I switch first on channel 2 and then on channel 3: but if I press them very quickly I switch to channel 13. But how much quickly? Thanks for the beta: works very well. Quote
Guest Lars_MQ Posted January 30, 2006 Posted January 30, 2006 This option will come in the next version of the beta. currently the value is set fix to 2 seconds. Quote
brasil Posted January 30, 2006 Author Posted January 30, 2006 Ok, 2 seconds are good. Thanks Lars. Quote
