Start an extern application?
lunkan
Hi all!
I hope that some expert on scripts, programming will help me with this problem.
Tell me how and I can do small changes myself.
I want to be able to start an exe file (program) from DVBViewers OSD Menu.
Make a new button and a script to this. Possible? :(
simply use the MenuEditor :( Available in the ServiceCenter
  • 2 months later...
Is it possible to execute a external program and at the same time stop the picture and sound from DVBViewer?
My problem is that i use DVBViewer to watch digital channels and a analog card with anouther software to watch some analog channels.
I want to be able to execute the analog software from the DVBViewer menu but as it is now the picture and sound keeps going in the background, i guess i need a script for this?
you're right, a script can help :bye:
set DVBViewer = getobject(,"DVBViewerServer.DVBViewer")
DVBViewer.sendcommand "CommandNr for DisableAV/StopGraph" 'look in your Actions.ini
DVBViewer.osd.execnewprocess "Program.exe","arguments",false,false
insert this script (as a program) with the menu-editor like this:
application: "c:\windows\system32\wscript.exe"
arguments: "x:\yourscript.vbs" //B
