SERENITE Posted February 1, 2006 Posted February 1, 2006 I am using DVBViewer 3.2.6 I want to change the source filter to be able to use Marf's source filter In the help document that came with the program I found under chapter 10 - Small filter guide that you have to go to setting/options/enhanced.... this option does not exist; probably the reference of a previous version of the program. I cannot find anywhere else in the settings this filter selection, although the file for this filter Skyavc.ax is in the filter directory. Can somebody help me ? Cheers, Phil Quote
Guest Lars_MQ Posted February 1, 2006 Posted February 1, 2006 The marfi filter is not supported anymore. No chance of using it. Quote
