Logical Channel Numbers
CX23882-19
This is probably another UK thing; I'm not sure if other countries use LCNs but in the UK they're quite important to some people.
We tend to like our DVB-t channels numbers to be numbered the same as their analogue equivalents (so BBC One is on 1, BBC Two is on 2, ITV 1 is on 3, Channel 4 is on 4, Five is on 5 etc.). Most DVB software including DVBViewer just adds them in the order that they're found, or groups them by provider (which does make sense for satellite).
I have no problems using the Channel Editor to create a new channel list but this is probably quite daunting to newbie users who are used to a set top box.
Guest Lars_MQ
I don't think this will be possible.
I like my channellist also in a special sequence, but there is nothing logic about it, it's how I'm used to it. But the feature mind reading of the DVBViewer is not planned until version 50.0 :)
And even in the "old" days you had to sort your channels on the TV-set/VCR or live with the sequence they were scanned :huh:
I can't tell if you are being serious or not. :)
It's not down to personal preference, the numbering comes from the transmitter, no mind reading required.
Guest Lars_MQ
Oh, the number from the transmitter is reflected in scan by frequency. That's the order the channels are scanned. There is no other order transmitted.
It comes from here:
Edited by CX23882-19
Guest Lars_MQ
Well to be really honest, there are 5 different ways to sort or presort your channels, (scan by provider or frequency, sort in the channellist, the channeleditor or build your own favourites list) so I don't see a urgent need for this feature...
And this are more ways than most other applications will give you :)
Please, please support LCNs on DVB-T. Even the pretty basic software that came with my card (AverTV USB2.0) has this feature...
More ways isn't always best - sometimes simplicity is what users want. Eg when I perform a scan, if it ordered the channels by LCNs I don't have to use ANY option to re-order them :)
Edited by pissedbob
  • 1 month later...
Hi there Lars,
I live in the UK, and agree that this would be a most welcome feature! Thanks in advance!
Cocksy
