jospo Posted February 2, 2006 Posted February 2, 2006 Hi, after installing Alpha Twinhan DTV USB device I found couple of problems when using DVBViewer: 1) Not working remote control - it works with original application but not with TwinhanUSB plugin (even plugin is enabled in Options, when try to learn some buttons, nothing happens). 2) When I run original application and exit it and run DVBViewer, no video or sound is available in DVBViewer. Only PC restarts helps. When I'm running TV in DVBViewer only, it is always OK. 3) Signal strength: my signal was 99-100% with Airstar USB, but with the same antenna with Twinhan Alpha USB it shows only 65-66% - still video stream is perfect without any corruption or hanging. Maybe some measure resolution problem? Tested with TwinhanDTV 2.608a and 2.606 drivers and latest DVBViewers (PRO 3.2.6 and GE 1.8.4). Quote
rriem Posted March 21, 2006 Posted March 21, 2006 First I installed TwinhanDTV 2.62 for the AlpaBox USB, it runs ok. After installing DVBViewer 3.2.6 the TwinhanDTV program crashes at startup. I read, if I would uninstall the Twinhan Software, it removes files necessary for DVBViewer (the driver is not removed, while uninstalling). Furthermore the Winmanager of the Wwinhan Software is neccessary for the remote control. What kind of files the installation process of DVBViewer are in conflict with the TwinhanDTV Software? Quote
