BDA Signal Strength/Quality
CX23882-19
I looked in the manual and couldn't find anything on this. Is there any way to get Signal Strength and preferably Signal Quality with BDA DVB-t devices?
Guest Lars_MQ
Depends on how good the programmers of the driver follow the standards. Some do it well (technotrend) others seems to have problems understanding the examples from microsoft... :) Nothing the viewer can do about.
BTW I assume you clicked on the progressbar in the statusbar of the DVBViewer and no strength is shown.
Yes, I tried that. It indicates 0% all the time. By the way, is that a strength or quality indicator?
Both indicators on the Nova-t PCI work in TSReader (using the standard BDA plugin, not the Hauppauge-specific one), MyTheatre and ShowShifter DVB.
Edited by CX23882-19
