just installed dvbviewer need help
djhandz
hi i have just installed DVBViewer and can not get any channels i have read the manual but it does not help i have a nova t pci card only had it a few weeks and it work fine with original software .. do i still need the software that came with my card or not i do not know please please help me someone thanxs i am using DVBViewer 3.2.6.80
Edited by djhandz
I'm a newbie too (installed it yesterday) so this is fresh in my memory.
Your card is a Nova PCI which means it's DVB-T, so to get a list of terrestrial channels (-T) you need to download TransEdit Scanner & Editor from the download section.
Run the .exe and select "Type" as Terrestrial and then do a scan (may take a few minutes) then save the channel list out as an .ini file.
Then from the channel settings menu of DVBViewer you can import the .ini file with all the Terrestrial channels. I'm in the UK where it's known as Freeview.
Hope this helps,
Ricky Dee
http://www.digital-air.co.uk
