djhandz Posted February 5, 2006 Posted February 5, 2006 is it possible to use the remote that came with my haupauge nova t pci card with DVBViewer thanx Quote
makinjr Posted February 5, 2006 Posted February 5, 2006 Try my solution. You can find it in DVBViewer "General" forum. http://www.DVBViewer.com/forum/index.php?showtopic=10925 Hope this helps you! Jarmo Quote
makinjr Posted February 5, 2006 Posted February 5, 2006 Here is my irremote.ini. Remember to add c:\program files\DVBViewer path to the end PATH environment variable (Control Panel/Performance/System/Advanced). Irremote.ini Quote
