Difference between .mpg and .m2p files
skysat
In the Recorder Option window you can choice two different kind of mpeg recording: you can choice to register a .mpg file or a .m2p file.
What's the difference between these two file formats and extensions? Is it only a matter of extensions or the file recorded in these two different ways are somehow - even just a little - different?
If there's not even the smallest difference, why does the software give us the possibility of this choice?
..different programs sometimes want different extensions (w00t) But I agree, it can be confusing. :radscorpion:
Excuse me for insisting on it :bounce: , but I still don't understand. Is it just a matter of extensions or there are some - even little - differences between the m2p and mpg files, between their structure, usability or compatibility?
Same content, different extension. That's all.
It was introduced for rework applications that want .m2p (= MPEG2 program stream) as input. Saves renaming.
