Recording in TS: only first audio track
brasil
I trying to record in TS format a movie (with double audio and telext subtitle): if I see live TV I can switch from one audio to another and I am enable to see telext subtitle.
In the TS file there are two audio track and one subtiutle track but I can hear only first track: second track seems empty and no telext subtitle.
I use DVBViewer pro 3.4.9.2 and in recorder setting I have set (in ts format options) all audiochannels, telext and dvb subtitle.
Can you help?
Thanks in advance
I just tried also with DVBViewer pro 3.2.6 and also with videorecorder plugin: same results.
Please, help me.
Have you tried to re-scan the channel(s) in question?
Remember, with the VideorecorderPlugin you need to check the "+ Additional Audio"-Box in the Channels-Tab.
I found the problem (but not the solution).
The second audio track it's recorded in TS file but it's "scrambled" (projectx tells me).
Do you have a solution?
Thanks
Guest Lars_MQ
The CI Version? And you use the non BDA drivers I guess?
Well twinhan only records one audiochannel with this drivers. There are current BDA drivers which can record all audio channels (on encrypted channels). Christian (Hackbart) is using this Card with the BDA drivers.
