more user friendly OSD zapping ?
ylber
There are some issues that can make more userfriendly TV-zapping:
1. when you are zapping thru the channellist-osd
when i press menue then i go to the channellist it comes to the favorits you select the Folder and select the N-tv channel ,(see atachmentin the News OSD folder ) then you quit with the M-keyboard buttom,
after that I comme back to the channelist OSD and I need to press again News OSD folder of the favorits and select the next channel after the N-tv-channel
can it be saved that i comme back to the same channel into the News favorites folder,
2.when you choose the time line in OSD,you can't see the channels in the favorites order but just like the provider list ?
Is there a solution for this ! or are you working on this ?
Guest Lars_MQ
Have you tried OSD-Blue (Contextmenu) ?
Guest Lars_MQ
Please NO support questions via unwanted PM!
Timeline -> OSD Blue (by default F9) -> In the OSD-Contextmenu there is a filter setting. just select it, I think it's persistant... The same goes for the EPG-Now window.
