feature request: change mousewheel function
rmn
it would be great, if the mousewheel function could be changed just by pressing the wheel (button3)
so you could use the wheel for volume control and to zap through the channels at the same time
greetz R-M-N
Guest DAvenger
This would be SUPER COOL :):P
How come it's not implemented already :rolleyes:
Guest hackbart
maybe this is caused by the reason that i never ever thought about it...
By the way there is a great function in the new netscape explorer and opera (i guess). If you move the mouse, like in Black&White, you can execute functions. If you paint an "N" you can open a new window etc...
Guest Michael
maybe a thing you can work on :rolleyes:
These 'mouse-gestures' for me never worked that good. I mostly had to repeat them....
