Where to find freelnb-tool ?
sasha
Well I've searched this forum for this tool and th eonly thing that I could find is this empty link: http://www.DVBViewer.com/download/freelnb.zip
Is this tool still available ?
If it is, could anybody be so kind to attach it here or post a valid link.
Thank you,
Sasa
I have freelbnb.exe in my DVBViewer TE installation folder, by version 4.3.2.
But in DVBViewer Pro you can make "Disable LNB on completion" in "Extended" under "Option".
The DVBViewer GE make LNB off by closed the software.
In the English Instruction for GE from Member Area under "Configuration in Setup.ini" you can find a option to prevents DVBViewer GE from switching the LNB power supply off when it is closed or set to standby mode (via commandline parameter -c).
Edited by hdv
ok, thank you.
