Please help me with mce remote!
cyclope
I buy the latest DVBViewer pro but I can't use mce remote. I downloaded mce plugin and put mymce2005.dll in the plugin directory and activate it. But only few buttons works (may be system functions up down etc.). How to use the plugin? Please help me, I read that mce remote was natively supported by the full version of DVBViewer. Is there any ready to use configuration files? Why I can't learn codes from mce buttons as: greenbutton (I like to start DVBViewer), Live TV, EPG TV, etc ? Is there any other possibility to use all buttons of the mce remote (like in win mce 2005) under win xp pro sp2?
Thanks.
Just go to the options and the input section. There you select the function you want to map in the list, you enter the learn mode with the learn button nand you press the key you want to associate on the remote. That's all! You obviously have to repeat that for all the keys.
Manual
I agree that having that preconfigured would be nice.
