twsms Posted February 16, 2003 Posted February 16, 2003 Hi, until yesterday I used 2 DVBS cards simultaneously, 1 Technotrend and the skystar 2. This makes it possible to view one program and record another using a TWIN LNB. Unfortunately my Technotrend board failed yesterday, it is obviously defective. Now I would like to find out if it is possible to use 2 Skystar2 cards in one computer simultaneously. One using DVBViewer or PROGDVB and the other one using the recorder.exe. Did anyone try this? TWSMS Quote
Griga Posted February 16, 2003 Posted February 16, 2003 There is a search function here in the forum... by using it you can find something like this. CU Griga Quote
twsms Posted February 16, 2003 Author Posted February 16, 2003 Hi, thanks! If the technotrend turns out to be definitely defective without a chance for repair I will give it a try. With my new PC (2 gig Pentium4) the advantages using a DVBS card with video output seems less important anyway. The skystar2 works very smoothly with the new PROGDVB, so maybe there is a good chance to record with recorder.exe and view with PROGDVB. cu TWSMS Quote
