New OSD Skin
i got an updated version of the Clarity Skin.
It can be downloaded from the members section and comes with TV- and Radio Mode.
Christian
Nice work, but why you called it Clarity OSD skin? In the zip-archive there is only a normal skin file, not an OSD skin.
Edited by Benson
yep, my fault - sorry for this.
Christian
Great Skin, thanks for this!
Btw. is it possible to program alpha blended (like winamp) skins so that we can have transparent "glass" skins like the windows in visa?
Very cool! :horror:
Thanks very much for this one! :)
Well Alpha not yet - i added it but i strongly recommend not to use it on videos. This is:
a ) Sloooow
b ) The video flickers if the owner window is semi transparent.
You can deal with two settings:
[Frame]
Shadow = 1
Alpha = 100 (0..100%)
The last one should only be used on radio mode!
Christian
[Frame]
Shadow = 1
Where to edit?
setup.xml? o:)
In the skin.ini or radio.ini of the skin source.
just put the skinfile in the following directory:
DVBViewer\Skins
and then chose it in the Menu
  • 3 years later...
Take in mind that "Clarity" is a GUI skin, not a OSD one; you can download it from here
