Taskbar and System Tray in Fullscreen
Bermar
Each time in fullscreen mode the taskbar and systemtray disappears. In the settings I have marked show in both. Is there any way to save these settings so that they appear in fullscreen ?
Guest Lars_MQ
Fullscreen means fullscreen, no taskbar, no systemtray. if you want a big window, size it manually.
The settings you set are saved and take care of the DVBViewer symbol in the taskbar and systemtray in windowed mode.
