Remember Mute state
pankov
HI
this is my first post in the forum so I appologize if I'm not doing it properly enough. I'll do my best to learn in the future.
I'm using DVBViewer Pro beta 3.4.9.14 and I think I found a minor bug.
When I mute the audio and exit the application when I start it again later the volume is not muted but set to 0 (minimum).
Isn't it possible to remember the the mute state and not lower the volume all the way down?
There is a similar issue posted before (octover 2005), but as it was marked as solved and I still find it in the beta from february I though I should report it.
P.S.
Guys, you should change a bit the topic "How to post bugs or problems correctly...". In it you mislead the user where to find the setup.xml file. In my case there was such a file in the DVBViewer folder but as I installed the application for "All Users" the right file was located in "C:\Documents and Settings\All Users\Application Data\DVBViewer Pro".
I'm sure you know this but I wanted to help others in the future
setup.xml
Edited by pankov
are there any developers reading here????
any comments?
I'm feeling ignored
:bye:
  • 3 weeks later...
