Sleeptimer
How tu use the plugin sleeptimer
this plugin don't work
please help me
thanks
The Sleeptimer Plugin is outdated, since DVBViewer Pro, DVBViewer GE and the Videorecorder Plugin provide the same timer functionality. Should not be used anymore.
please help me,
how to make to shutdown DVBViewer at the end of a certain time
example to shutdown DVBViewer at the end of one hour without making recording
thanks
Which DVBViewer version do you use?
Read here how it can be done with the Videorecorder Plugin.
Hello,
I have to it last version beta (3.4.9)
and indeed I have just tested the plugin and still thank you for information
just small precision, is it possible to use the plugin in OSD. it is more practical with a remote control
still thank you
Guest Lars_MQ
For now the osd slepptimer plugin does not work with the current beta (as stated in the readme of the beta). There will be an update as soon, as the restructuring in the beta is closed.
