Standby / resume
What is the best way of putting DVBViewer system into standby (S3) so that the
DVBViewer will automatically resume on system resume ? I have used UICE with
a macro (close DVBViewer - standby - restart DVBViewer).
This system has a problem: restarting DVBViewer is too quick after resume so
that USB card has not enough time to resume. For some reason adding delay to
startup.ini or UICE command does not work. Do not understand why.
Another problem is that closing system when a recording is going on causes
problem.
You can use the DVB Task Scheduler for it. You must let him run in the bauckground. On the 2nd settings tab, you will find an option "Restart on Resume". There you can set a time to wait in seconds , befor the DVBViewer starts after Standby or Hibernate.
