Terrtec Cinergy 1200C Native driver?
Nick [D]vB
Can someone tell me if the Terrtec Cinergy 1200C can work with any version of DVBViewer using the native driver [NOT BDA driver] ?
I do not want to use the BDA driver because it is not stable and it is for a low spec PC. Sorry for posting in english, thanks for you help.
Cheers,
Nick
No, that won't work.
Actually the 1200C needs two BDA drivers, as you might know, one for the tuner and one for capturing. People in the German forum reported that DVBViewer works pretty well if the capture driver (only that!) is replaced by the one from TechnoTrend.
Thanks for the tip! ;)
Edited by Nick [D]vB
