pankov Posted March 10, 2006 Posted March 10, 2006 (edited) I think I've found a bug in the latest oficial version (3.2.6) and latest beta (3.4.9.14) too when using a VMRenderer (VMR7 or VMR9) to display a 16:9 channel (or at least a 16:9 HD channel HD-5 that I saw this). The problem is that the OSD is not usable with the mouse. It's visualized in the 16:9 frame but it reacts to mouse clicks in 4:3 area ... may be I'm not clear enough ... I'll try do explain it better with an example: when I open the OSD for selecting a channel there are 5 buttons on the bottom (Down/Up/Last/Next/Preview). When I click on their position on the screen (which is in the 16:9 frame of the picture) nothing happens. This is bacause I don't have any channels in the list near the bottom. To click on these buttons I have to predict where their position is in the 4:3 frame (the black bar at the bottom) and this way I can use them. As I think that this is not supposed to be this way I decided to report it as a bug. The same problem applies to the hotspot zones in the top corners (left for channellist OSD and right for OSD Menu). With 16:9 programms these zones are positioned differently than 4:3 programms which is somewhat not intuitive for the normal user. setup.xml Edited March 10, 2006 by pankov Quote
pankov Posted March 17, 2006 Author Posted March 17, 2006 are there any developers reading here???? any comments? I'm feeling ignored Quote
pankov Posted March 24, 2006 Author Posted March 24, 2006 did you guys (support) see this? Am I doing something wrong or this is a confirmed bug in the application and is already fixed for future versions?? Quote
