knutwuchtig Posted March 14, 2006 Posted March 14, 2006 Hi, I am using Technisat SkyStar II PCI and DVBViewer TE. I did scan twice and miss some programs - Das Vierte, e.g. - which I can receive with my Technisat box and TV. Same satellite dish. Is this a limitation of DVBViewer TE? Regards Knut Wuchtig Quote
knutwuchtig Posted March 14, 2006 Author Posted March 14, 2006 No. <{POST_SNAPBACK}> Do you have an idea, then, why it does not work? Regards Knut Wuchtig Quote
hdv Posted March 14, 2006 Posted March 14, 2006 Hallo, please import the ini File in your Channellist. DAS_Vierte.zip Quote
knutwuchtig Posted March 15, 2006 Author Posted March 15, 2006 Hallo, please import the ini File in your Channellist. DAS_Vierte.zip <{POST_SNAPBACK}> Thanks a lot. But how to do? I have DVBViewer Technisat Edition. The file, e.g., runs FEC=5 and DVBViewer Technisat Edition for manual configuration offers 5/6 only. I would appreciate a short instruction very much. Regards Knut Quote
hdv Posted March 15, 2006 Posted March 15, 2006 Hallo, The file, e.g., runs FEC=5 and DVBViewer Technisat Edition for manual configuration offers 5/6 only. if you put the FEC option to "FEC AUTO" it must run, here it's work good. Quote
knutwuchtig Posted March 15, 2006 Author Posted March 15, 2006 Hallo, The file, e.g., runs FEC=5 and DVBViewer Technisat Edition for manual configuration offers 5/6 only. if you put the FEC option to "FEC AUTO" it must run, here it's work good. <{POST_SNAPBACK}> Yes, but how to import the file?Tto copy in which folder? Quote
hdv Posted March 15, 2006 Posted March 15, 2006 hallo, Yes, but how to import the file?Tto copy in which folder? open the channellist, click the import button on bottom of channellist. Now you must select the type of file dialogue and now you must go to the folder where the DAS VIERTE.ini file is. With the shift button and the cursor keys can you move it in the channellist. Quote
knutwuchtig Posted March 16, 2006 Author Posted March 16, 2006 hallo, Yes, but how to import the file?Tto copy in which folder? open the channellist, click the import button on bottom of channellist. Now you must select the type of file dialogue and now you must go to the folder where the DAS VIERTE.ini file is. With the shift button and the cursor keys can you move it in the channellist. <{POST_SNAPBACK}> Thanks a lot. Did not work, however. I will reinstall system and try again. Regards Knut Quote
knutwuchtig Posted March 16, 2006 Author Posted March 16, 2006 hallo, Yes, but how to import the file?Tto copy in which folder? open the channellist, click the import button on bottom of channellist. Now you must select the type of file dialogue and now you must go to the folder where the DAS VIERTE.ini file is. With the shift button and the cursor keys can you move it in the channellist. <{POST_SNAPBACK}> Thanks a lot. Did not work, however. I will reinstall system and try again. Regards Knut <{POST_SNAPBACK}> I now managed to put "Das Vierte" into the list. Needed some handwork. But now the VR does not start but produces an error message. I will try on, but I now have data for "Das Vierte". Thanks again for help. Regards Knut Quote
