Stream error and out of sync record
tisurame
This only happens with this specific channel...
When recording, if I get a stream error, the rest of the record will be out of sync (unless I split the file).
So, it's there any solution for this ? Maybe a option that can split the file everytime a stream error is detected.
Thanks.
I'm using a Athlon XP 2400+, 512mb of ram, Windows XP and a Skystar2. This happens with DVBViewer Pro or GE (any version) or any Technisat driver.
Also happens with others DVB softwares.
Edited by tisurame
... :bye:which specific channel???
mmmh, very annoying from my point of view...
...have you already tryed to "clean" the corrupted file with PVAStrumento?
You probably lose some GOP where the stream error occours, but it seems to me that you can obtain, at once, rather the same result you have got by splitting the file...
