Technotrend DVB-S PCI Budget
koecks
I thought that the TT DVB-S PCI Budget was supported by DVBViewer ? Am I using the wrong drivers ?
I have tried using the most current ones (january 2006) from TT site - but no luck ?
Have you got any suggestions ?
Cheers
Thomas
Guest Lars_MQ
Which DVBViewer are you using? which drivers? only bda is supported.
DVBViewer Pro (Beta)
I have now rolled back to Technotrend 2.5.0.0 drivers (17.06.2004) - how do I know if they are BDA drivers (isn't that only DVB-T from TT ?
/Thomas
Guest Lars_MQ
They have to be compatible with mce2005 that means they are bda. and as for your drivers don't work they most likely are no bda drivers.
