nicc Posted March 19, 2006 Posted March 19, 2006 I'm in the UK trying to get all the freeview channels on my DVB-t 100. Using DVBViewer it only finds a subset. So after reading I got hold of transedit 2.5 and it too doesn't find all channels (didn't find any - strange!) The thing is using the Demo version (transedit 2.3.101 MMC Core) it finds them all - just won't export them as it says DVBViewer isn't present! I guess it doesn't actually check since a later version is present. So any idea why the proper 2.5 version won't find what the demo one does?? Quote
Griga Posted March 19, 2006 Posted March 19, 2006 Settings -> Hardware: Is your device listed there? Did you try the "Stop stream while tuning" option? Quote
nicc Posted March 19, 2006 Author Posted March 19, 2006 worked - as I had it in the same directory as the normal version but was running GE I guess there was a prob Quote
Guest Lars_MQ Posted March 19, 2006 Posted March 19, 2006 I guess there was a prob Oh yeah there was a prob sitting in front of the pc I guess you had the setting activated, that only shows updated channels in compare to the channellist of the DVBViewer... But you're not the first one, I did quite some debugging till I discovered the cause Quote
