record only mode?
pastimer
I want to make recordings and view the recordings using UPnP software.
I tried progdvb with /NoGraph. This works great for broadcasting. But when i stream recordings to the UPnP client, after a few seconds the video freezes.
DVBViewer works much more stable but uses more resources. Can i stop mpeg-decoding (viewing) while recording on the server?
Thanks, Eppo
Edited by pastimer
Use disable av and start with -c param.
I tried both suggestions, but to no avail: I use Athlon XP 2600+ windows xp, 512 MB. I have now 85% avarage cpu utilisation while 'tuned' . With progdvb i have only 15% cpu utilisation !
It does not make a difference whether i effectively record or not for cpu !
What is DVBViewer doing??
Regards, Eppo
Edited by pastimer
Good question.. ..it's teasing you :D If you still have such a high cpu usage, the graph is probably not switched off properly.
Some applications are like french cars. When everybody else had the indicator on the left side of the steering wheel, citroën had it on the right.
You could ask for a button to switch-off AV :bye:
Guest Lars_MQ
The question should be what is your system doing?
So have a look on how to post informations and we will see what's going wrong with your system.
OK. Thanks for the tip: Here is the output of the supporttool...
So i start obeying forum rules and the tread dies instantly? :blink:
Thanks for looking into this guys!
