derevo Posted March 29, 2006 Posted March 29, 2006 this card has 2 receivers. dvb-t and dvb-s. does DVBViewer pro support this card?? Quote
taky Posted April 3, 2007 Posted April 3, 2007 this card has 2 receivers. dvb-t and dvb-s.does DVBViewer pro support this card?? Support - i don't know, but DVBViewer + Lifeview FlyDVB Trio DVB-T/S work "almost". remotecontrol, don't work, and DVBViewer can use only one LNB correct, if system include DiseqC -> DVBViewer can't choose between them quite correct. Quote
Griga Posted April 4, 2007 Posted April 4, 2007 and DVBViewer can use only one LNB correct, if system include DiseqC Maybe it can be fixed, if the driver is based on a known design. The most common one is the TechnoTrend method for passing DiSEqC parameters. It can be tested with TransEdit (-> members area), by opening the file TransEdit.ini (see Info Menu -> Configuration Folder) with a text editor and changing the Vendor.x=0 line of the according device in the [Hardware] section to Vendor.x=3 TransEdit must be closed when you save the modified file. x is a device number 0, 1, 2... etc. "=3" lets TransEdit believe that it's a TechnoTrend card and apply the according DiSEqC method. Quote
CoolKoon Posted May 14, 2007 Posted May 14, 2007 I do have a FlyDVB Trio card and tried this hack with TransEdit, but unfortunately it didn't help. Is there any other way to make the switches work? Quote
