ddawg Posted March 31, 2006 Posted March 31, 2006 (edited) I saw that a similar problem was discussed in Bug reports regarding DVBViewer Pro and EPG in Finland. The situation isn't exactly the same in latest DVBViewer GE beta, since this time around the event and the title are in different languages. So, if the event is in finnish, the title is in swedish and the other way around. The pattern of it is seemingly random. I've included a screenshot of the situation where I have colored the entries in swedish red and the entries in finnish blue: edit: on further investigation I noticed that the title contains in fact both the finnish and the swedish description. The title field isn't long enough to display all of the information, so you'll only see the first description which is in different language in respect to the event field. Edited March 31, 2006 by ddawg Quote
Guest Lars_MQ Posted March 31, 2006 Posted March 31, 2006 1. not a problem with the DVBViewer Pro Beta -> moved. 2. The DVBViewer GE doesn't support multilanguage EPG. Quote
ddawg Posted March 31, 2006 Author Posted March 31, 2006 1. not a problem with the DVBViewer Pro Beta -> moved.2. The DVBViewer GE doesn't support multilanguage EPG. <{POST_SNAPBACK}> Ok, so this is a non-issue, then. Installed latest beta of DVBViewer pro which seems to work as expected. I guess I'll put up with the half swedish epg, or switch to DVBViewer pro. Thanks. Quote
