jongordo8 Posted March 31, 2006 Posted March 31, 2006 I purchased an Air2PC card on ebay: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...AMEWN%3AIT&rd=1 Downloaded and installed the drivers and software from Technistat's version 4.4 Everything went smoothly installing the drivers and the software, however I cannot get any channels to tune in. When I do a scan it doesnt find any channels. Am I missing something, why isnt it working. I have tried scanning on the setting America (ATSC), America Cable (IRC), America Cable (STD) and I cant find one station when I connect my cable signal to it or a roof powered antenna. I know my cable is good and running. Can anyone help me with my issue? Quote
williadt Posted April 30, 2006 Posted April 30, 2006 I have the same problem, so hopefully someone who knows how to fix this will respond. Until then I will continue to play around with it. I purchased an Air2PC card on ebay: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...AMEWN%3AIT&rd=1 Downloaded and installed the drivers and software from Technistat's version 4.4 Everything went smoothly installing the drivers and the software, however I cannot get any channels to tune in. When I do a scan it doesnt find any channels. Am I missing something, why isnt it working. I have tried scanning on the setting America (ATSC), America Cable (IRC), America Cable (STD) and I cant find one station when I connect my cable signal to it or a roof powered antenna. I know my cable is good and running. Can anyone help me with my issue? <{POST_SNAPBACK}> Quote
tom_servo Posted June 12, 2006 Posted June 12, 2006 I too have the same problem and have spent days trying to figure this thing out. Has anybody found a solution to this? Quote
Guest Oliver Posted June 12, 2006 Posted June 12, 2006 Please post some more information: http://www.DVBViewer.com/forum/index.php?showtopic=2210 Quote
tom_servo Posted June 12, 2006 Posted June 12, 2006 (edited) Sorry about that, here's my info. I am trying to use an indoor VHF/UHF/FM "rabbit ear" antenna. I thought it didn't work because I needed an outdoor antenna, but jongordo proved otherwise. Thanks for the response! support.zip Setup.ini Edited June 12, 2006 by tom_servo Quote
tom_servo Posted June 13, 2006 Posted June 13, 2006 Bump....any additional help or answers on this? Quote
Guest Oliver Posted June 13, 2006 Posted June 13, 2006 Do you get a signal with another device at all, for example a stand-alone receiver? Quote
tom_servo Posted June 13, 2006 Posted June 13, 2006 I don't have any other ATSC source other than this card. I actually bought it for that reason, cause I'm cheap enough to not buy an actual HDTV set...I guess that's why it's going rough. Quote
bob51 Posted August 22, 2006 Posted August 22, 2006 Hi I am having the same problem, just no signal at all from the my cable or anywhere? Could it be just a bad card card? Thanks you for any help at all, I am new to this card and this software. Thanks again Quote
