pankov Posted April 1, 2006 Posted April 1, 2006 Is it possible to add an option to automatically hide the cannels OSD when a channel is selected? Or is there such and option already and I've missed it? I personally don't see the idea of leaving it on. If one is just looking for somthing to watch he can use channel up/down. If one is looking for a particular channel he will not need the OSD after the channel is selected. .... this is only how I see it Quote
hdv Posted April 24, 2006 Posted April 24, 2006 Hallo, bump add the option himself go to Options -> Input -> Add in the Actioneditor you must enter this two points from the right dropdown menu into the left window after that you can make a keyboardletter for shortcut this then you have select a channel in channel OSD drop your new shortcut that will be tune the channel and close the OSD Quote
pankov Posted April 24, 2006 Author Posted April 24, 2006 HI I must say that this kind of works but it's a very "nasty" workaround for the thing I want to accomplish. As you suggested there should be a different shortcut for this "special" OSD OK. And as expected there are limitations other than the ease of use and it's the number of keys on the remote. So for me this is not a usable solution and I'll have to keep asking for an option to automatically close the OSD after selecting a channel. btw what could be the reason to leave it on? Quote
pankov Posted October 14, 2006 Author Posted October 14, 2006 as I've seen in other sections of the forum there are other users requesting this option so I'm rerequesting it again Quote
