Help......
outofhood
Please advise in simplest of terms, how I can use DVBViewer with Hauppauger WinTV-HVR900... I cant seem to get started! DVB Pro downloaded, and seems to work on screen, but I cant work out how to hookm up with the HVR900. Please try and keep it simple! Thanks.
Guest Lars_MQ
Which DVBViewer version? Do you use the bda driver?
We're talking computers here there is not such a thing as simple. :bye: You must provide at least the necessary informations if you want help.
Iam using a Dell Dimesion 5150 with P4 3ghz, !1Gb RAM and Win XP home. I downloaded the paid for--pro version of DVBViewer, if the bda driver was inclided in this package, then yes... Do I ned to download this driver, and if so from where? Please be patient!
  • 11 months later...
Hello friend, how are you doing? I have the same HVR900 stick and seek a replacement for that infamous Hauppauge software. Did you make the HVR900 work with the DVBViewer? If so, can you recommend to switch? :bye:
Cheers,
Computermaus
ps. You should have a BDA driver; it is a squarre little B/W icon down right on the screen that looks like a bar code label and came with the Hauppauge CD ROM.
