New User
Hi, im a new user of DVBViewer having just bought a Skystar2 card and having limited success decoding H264 using a piece of software called "TSreaderlite"
Now ive read the topic in the HD forum but where is the download at for me to use.
Is there either a free .ts recorder plugin for the newest release that came on Technisat disks or even plugins to view on that piece of software
Thanks
Edited by remlap
Hello !
Sorry , but could you please specify what you mean?
TS ist NOT h264.
T
S= Transportstream which normally contains MPEG 2 , and sometimes H264.
For Playing TS the TS Player plugin from Griga (Members Sections) ist quite good.
Additional H264 Filter may be needed.
Hence also usable Software for
TS and MPEG and H264 ist
Media Player Classic (has NOTHING to do with Micro$oft) and needs installed Filters and Codecs in the System.
VLC= Video Lan Client (Dos not need any Filter in the System, because it uses its own ones.) Plays MPG, TS, H264,XVID,DIVx, MP4 and so on....
Sure what I wanted really was a way to record the transport stream which is in H264 and view it in Media Player Classic or VLC
Or even a way to watch it without having to record the transport stream and do it live
Hope thats easier to understand
The main reason I would like to learn how is due to the fact that BBC will be using DVB-S and H264 for thier first trials in HD of Wimbeldeon and World Cup etc.
Thanks.
Edited by remlap
Are you a registered user of the DVBViewer?
If yes, read the description. Either the pro version or the GE can record H.264 as a transport stream.
If no, get yourself a licence for only 15€
:bye:
:bye:
Im sorry but what classifies as a registered users, ive got a copy that came with my skystar2 install CD.
that´s why I moved the topic. This forum is not a Technisat_help_forum but a forum about the DVBViewer
:bye:
Thanks, still is it possible to decode H264 using this edition then I didnt relise that there was differences in the software.
If not how easy is it to setup H264 on the premium versions?
Edited by remlap
You´ll need the premium version. But beware that you need a very powerfull pc to decode h.264 though it´s very easy to record the transport stream. Most h.264/avc streams are transmitted in dvb-s2. Your hardware (SS2) is not capable to receive dvb-s2 !
I understand this, BBC will be using DVB-S for a time then switching to DVB-S2
Ive downloaded previously uploaded by other people .ts files which are using H264 and they play okay in media player classic.
Cheers for all the info.
Hi, ive just purchased a copy of DVBViewer and waiting to get the exe and installed a full version of the Coreavc code :)
I hope to be rolling soon.
