hama usb infrared adapter + dvb viewer
hi,
i'm using DVBViewer and i've got a usb infrared adapter for a remote control. Is there a plugin which allows the DVBViewer to control the usb receiver. The winlirc plugin only works with serial infrared receivers....
  • 4 weeks later...
hi,
I had a same kind of problem with Terratec Cinergy T2...rc requires running Terratec rc-software and it didn't manage all the buttons, so I desided to search for a wireless mouse and found "Targus Wireless Mini Optical Mouse Presenter". With OSD and mouse you can do more than rc...
