mobyduck Posted April 16, 2006 Posted April 16, 2006 Thank you for inserting dvb subtitles also to TE version. Would it be possible that after selected the 'show subtitles' option the software would remember the selection every time you change to channel who sends those subtitles and it would recognize if the channel starts to send those while watching the channel? Now it's a bit uncomfortable when you allways must do the selection again after changing the channel. Especially when you have timed a recording. By the way, how could I include those subtitles to dvd image file too? Quote
Guest Lars_MQ Posted April 16, 2006 Posted April 16, 2006 Try options -> dvbsubtitle -> show automatic. Quote
mobyduck Posted April 17, 2006 Author Posted April 17, 2006 (edited) Try options -> dvbsubtitle -> show automatic. <{POST_SNAPBACK}> I can't find that: if I select settings and options the only subtitle option I can find is teletext and epg - subtitles - parse atsc subtitles . Edited April 17, 2006 by mobyduck Quote
Guest Lars_MQ Posted April 17, 2006 Posted April 17, 2006 oops sorry, I didn't noticed your talking about the TE version. Quote
