Tweaking the performance of streaming?
Jipatsu
I got DVBViewer working with the help of developer staff, thanks for that.
so now I can see the shows and channels. Only problem at this moment is that stream is a little bit laggy and the picture sometimes is not as sharp as it should be.
can I solve this problem by tweaking the settings of DVBViewer or is the problem in my card or monitor?
although I have tested other programs too like ProgDVB and I didn't have anykind of this problem.
I'm using the Beta version of DVBViewer and my DBV-card's drivers are up to date.
Cheers
Guest Lars_MQ
the display quality depends on the used video decoder. Try different decoders in Options -> DirectX.
