Scheduler does not add tasks
AndyStone
I have downloaded the DVB scheduler plugin and ticked the check box in the extended options to use MS Task Scheduler.
I select a program from the EPG to record and it appears in the record seetings. When I close the viewer it does not appear to start the scheduler, although I did get the MS prompt each time asking if I wanted to start the DVB scheduler as it wasn't a recognised exe. I have since checked the box to stop asking me this so I don't get it anymore.
I have also tried manually starting the scheduler and then perfoming the above, the DVB scheduler does start and warns me the DVBViewer is running.
Iether way no task is generated for the recording.
Interestingly I never got the scheduler to work with WINTV (it appeared in the task bar but you could not maximise it).
I can however add and schedule tasks which run successfully on Windows task scheduler for things such as Windows clean up and disk defrag.
Any ideas ?
