Airstar Telestick help please
bozz
Hi
Just bought a TechinSat Airstar Telestick, installed it but I am unable to see any TV. When I try to scan for channels, it never finds any despite my Telestick being hooked up to the antenna I use to recieve Freeview TV.
So far I have not found any help in the manuals or on the net (until I came here) It also seems that the EPG & Teletext buttons do not work (cannot be depressed)
Please help !
Support zip attached
Edited by bozz
i have used an active antenna with Amplifier. So i have found all channels. Wich program do you use? TE or Pro? I'm using TE. It runs very instabil on my PC (partly no reaction)
