OSD shows up only partly
mlehtola
I have a problem with OSD, it shows up only partly, see the picture (picture doesn't show the tv because "print screen can't capture it).
Some details:
pc: HP Compaq nw8240, WinXPsp2, 2GB RAM
graphics card: ATI FireGL V5000, 1920x1200@32bit (tried also 800x600)
tv-card: Terratec Cinergy T2 (usb, dvb-t)
DVBViewer: 3.2.6 and 3.4.9 beta (both act the same way)
rest of the information you can find from the attached file, there's some errors on DVBViewer.log that might help to figure out what might be wrong.
Everything else is working just great!
btw. it's quite difficult to search the forum when "osd" has 3 chars and you can search only with 4 or more chars :arrow:
Edited by mlehtola
Guest Lars_MQ
The windowdef.xml seems to be damaged. Please rename/delete it. It will be recreated on next DVBViewer start.
That was it, thanks a lot! What a great software.
